Hi, I recently picked up a Fostex B 16 reel to reel.... Everything turns on and mechanically seems to work as it should but I'm getting no audio signal running through the machine. No playback from tape, no record levels. I plugged an ipod into one of the inputs and and from the output I plugged into a mixer... when I cranked the gain I was getting a very very faint signal of what I was playing on the ipod.
I researched a bit online and found someone with a similar problem. They were able to fix their machine by replacing 3 of the voltage regulators (+12, -12, +5). I have a voltage meter but problem is I don't know where the V reg's are located or really what they look like... Any help or suggestions would be very appreciated!
I've attached an image of the inside of the b16
