Analog Pitstop
Active member
I have access to such instruments (dedicated SA with Phase noise modules + software), but not the right ones.
At home I have one that can do -136dBc/SQRHz and at work I have a few ones which can resolve -170dBc or so. Milion times more than enough for a tape machine.
Problem is, my models do not lock at 150KHz. Too low frequency. On the bright side: at least I know where to buy the right ones
But:
Even if I find such instrument, what is the use without a link to know how to interpret phase noise vs. SNR in tape recorders? Hearsay
Even if I find the instrument and the theory for analysis, what is the use without help (comments or a link?) to explain the noise bump around the signal?
So far, I observed these points about "the blob":
- it depends on tone frequency
- it depends on W&F and tape path
- it depends on rec head quality (sub-micron geometry definition of gap's trailing edge + gap length + head material)
- it depends on tape thickness, formulation and age
- it depends on tape speed
- it depends on bias frequency and its amplitude stability
- it depends on signal amplitude and noise floor
- and... sometimes it depends on how many times the tape was recorded/erased (memory). Hello SM911? What an unpleasant surprise, from you!
Counting the subjects, when I will know all these answers I can probably write a nice book.
Counting the literature sources as close to zero (so far), it also means that when I will write such a book, it MUST be one without any references!
So, then what's the point for such effort?
This thread is to help OP to do something with his x16tr machine. Originally he stated that only tape logic is busted&needed. Then this subject of tape-SNR read by SA instruments is off topic, no matter how much or less I like it.
But:
