gepicaster
Member
Speaking of topologies, may I ask, which one from below you would recommend?
Why?
View attachment 106018View attachment 106019
Why?
The key element here is knowing the inductance of the PB heads. It will determine what front-end is needed (FET or bipolar) and what operating point to choose.One thing I need to improve is the amplifier hiss. It's not horrific, but I'm sure the s/n ratio of the amp itself could be improved.
Definitely a low-Z head. About 1k-1.5k in the critical 2-6 kHz range. The classis answer would be a bipolar front-end biased at about 1mA. It could also be a VLN FET such as 2SK170 running at 2mA.The inductance is 50mH, and an ohm test shows roughly 120 ohms IIRC.
Probably not. 5532 has an OSI (optimum source impedance of about 7 kohms.As far as bipolar goes, I wonder if a Ne5532 front end would do a good job, as opposed to a discrete alternative....
