I've recently finished a system rack and one module of my 10 HP 3 RU system.
The module contains 2 mic pre amps based on the TLA Ian Thompson-Bell has designed.
The 10 HP design allows to stuff 16 pre amps into a 19" 3 U rack or, as seen in my first attempt, to put 8 pre amps plus PSU into a 19" "Baugruppenträger".
28 + 10 HP were used for the PSU, there is a remainder of 6 HP when stuffed with 4 modules HP. Non used space is currently filled with whatever I found...
Module:
Frequency response:
Noise floor:
Module:
Frequency response:
Noise floor:
