Winston OBoogie
Thank you sir. Again, nice workHolger said:Yes, the pins are from Harwin, Mouser # 855-H3161-05
Tubes get a bed press for producing a lot of heat, probably due the that fact that the power tubes in guitar amps do get very hot. But mic pres are completely different. One of Holgers modules will probably consume less than 10 watts. Its front panels will probably rise about 5 degrees above ambient. 10 of these in a 19 inch space is 100 watts.jensenmann said:Wow, Hoger, I´m impressed. That´s a lot of parts crammed into little space. Does it heat up a lot?
In particular I´m interested if the heat transfer through these small tube pins to the PCB is a problem.
