CurtZHP
So, the adventure continues....
Bench testing my "Heavy" preamp, I plugged a headphone amp into one of the outputs and a tone generator into the input. Played a bunch of sine waves into my ears on both channels and all was well. It sounded quiet and clean. (But we all know that's not how this will end....)
Next I plugged in a dynamic mic (Shure SM-58). All good. Sounded kind of bright for my taste, but that could have been my headphones (Sony 7506's).
Next came a condenser mic. Flipped on the phantom power and was immediately greeting by a nasty loud buzz. Ack!
Disconnected everything. Checked XLR pins 2 and 3 against pin 1 with a voltmeter and both show 48VDC. Rigged up the scope, and this is where it gets entertaining. There is definitely a very ugly square wave sort of mess riding on that rail. I've attached the schematic for your amusement.
15VAC goes through a voltage multiplier/half-ass wave rectifier and hits a capacitor on its way to the voltage regulator. The ugly I'm seeing at the XLR jack is also seen on the output of that regulator, as well as the cap downstream of it (C112). My first assumption is that that capacitor, all by itself, is simply inadequate to properly smooth out the ripples, so I'm inclined to replace it with two larger ones in parallel.
Unless I'm missing a much bigger problem....
