substitute
Soundcraft Spirit Mixer stuck in PFL solo mode
« on: June 01, 2018, 09:04:36 PM »
Hello, hello, hello, looooooooooooooong time no see.
I have a Soundcraft spirit folio mixer that is stuck in PFL SOLO mode that I'm working on.  Here are the details
- The SOLO indicator LEDS on the two stereo channels are constantly on regardless of switch position
- The master PFL indicator LED is constantly on and the master meters behave as though it is in PFL mode
- Even though the SOLO indicator is on either way, audio from the stereo input channels doesn't route to the PFL buss unless the switch is depressed
- The SOLO switches on the channels test appropriately for continuity and behave as expected
I'll attach screen shots of the SOLO area of the schematics for both the stereo channels and the master section following this post.
Here is a link to the complete service manual, pages 18 and 21 are what I'm looking at.
https://www.dropbox.com/s/siya6u7guwva0zd/soundcraft_spirit_folio_racpac_sm.pdf?dl=0
Here's a link to the user manual
https://www.soundcraft.com/en/products/spirit-racpac
My current suspicion is that some component (perhaps Q3) in the master section has failed and is letting the +17 supply through to the EN buss and also activating the main PFL LED.
« Last Edit: June 02, 2018, 06:20:20 AM by substitute »
substitute
Re: Soundcraft Spirit Mixer stuck in PFL solo mode
« Reply #1 on: June 01, 2018, 09:05:18 PM »
Stereo Input Solo detail attached
substitute
« Reply #2 on: June 01, 2018, 09:06:00 PM »
Master PFL detail attached
JohnRoberts
« Reply #3 on: June 01, 2018, 11:31:21 PM »
it's after beer o'clock so I will just answer in general.
Look for something wrong with the solo/pfl logic bus...  it may be shorted or floating at some incorrect voltage.
Visit https://circularscience.com to hear what properly "cleared" drums sound like.
substitute
« Reply #4 on: June 02, 2018, 06:23:14 AM »
It is (or was) and on a Friday no less. Now it's coffee o'clock. Unfortunately the schematics don't have any voltages notated and I don't know enough about these types of transistor switching circuits to know what to expect. I'll post back with voltage measurements a little later.
substitute
« Reply #5 on: June 02, 2018, 08:24:08 AM »
Here's some intel for the transistors in the master PFL section...
Q3
B 16.35v
E 17.02v
C 17.91v
Q4
B 6.79v
E 0v
C 16.33v
Q5
B -16.26v
C -16.85v
E -16.84v
Q6
B -0.64v
E 0v
C -0.14v
Does anything jump out at anyone?
JohnRoberts
« Reply #6 on: June 02, 2018, 11:25:06 AM »
OK there is trouble in PFL 'ville
Q3
B 16.35v
E 17.02v
C 17.91v
Q3 is almost valid... it appears turned hard on, while a little unusual for collector voltage to be higher than emitter that is pulling it up.  I will ignore that as a measurement artifact.
Q4
B 6.79v
E 0v
C 16.33v
now your talking,,, Q4 is busted. Unless base is actually 0.67V instead of 6.7V  :o
Q5
B -16.26v
C -16.85v
E -16.84v
q5 looks OK
Q6
B -0.64v
E 0v
C -0.14v
q6 looks OK..
Recheck base voltage at Q4, if actually 6.7V that is your problem.
substitute
« Reply #7 on: June 03, 2018, 09:38:48 AM »
Just double checked, the base of Q4 is indeed 6.7v.  I'll report back once I've replaced it.
Thanks for the insights!
moamps
« Reply #8 on: June 05, 2018, 04:05:47 AM »
Q3
B 16.35v
E 17.02v
C 17.91v
Collector of Q3 can't be on higher potential than emitter. Check this transistor also.
Q3 should have base or emitter resistor, or it is just schematic error.
substitute
« Reply #9 on: June 05, 2018, 07:21:53 AM »
Will do.
JohnRoberts
« Reply #10 on: June 05, 2018, 12:26:29 PM »
I already ignored that as a measurement artifact (error) since the PS rail voltage is 17V making 17.9V extremely unlikely.
JohnRoberts
« Reply #11 on: June 05, 2018, 12:27:13 PM »
I already ignored that as a measurement artifact (error) since the PS rail voltage is 17V making 17.9V extremely unlikely, and a bad transistor will not generate extra voltage.
moamps
« Reply #12 on: June 05, 2018, 05:11:33 PM »
What's more confusing to me is connection of Q4 and Q3. It can't work that way.
JohnRoberts
« Reply #13 on: June 05, 2018, 06:13:03 PM »
I suspect there are parts missing off the page,,, like a resistor in series with base of the npn to keep collector current modest.
it is not unheard of for mistakes in old hand drawn schematics.
abbey road d enfer
« Reply #14 on: June 05, 2018, 06:30:44 PM »
Why? Seems perfectly legit to me. Collector of NPN Q3 sinks current from base of PNP Q4.
moamps
« Reply #15 on: June 06, 2018, 03:49:19 AM »
Q4 is NPN, Q3 is PNP. Both work as switches. What's the base current of Q3 when Q4 is in ON state?
abbey road d enfer
« Reply #16 on: June 06, 2018, 04:33:59 AM »
That's correct, so Q4's collector sinks current from Q3's base.
Obviously there's a mistake regarding Q3's collector connection. It should go to R183.
moamps
« Reply #17 on: June 06, 2018, 04:44:17 AM »
I don't think so.  A resistor in base or emitter of Q3 is missing, as I already stated.
« Last Edit: June 06, 2018, 04:53:15 AM by moamps »
abbey road d enfer
« Reply #18 on: June 06, 2018, 05:04:55 AM »
You're correct, I didn't see that Q5 is taking care of the LED.
JohnRoberts
« Reply #19 on: June 06, 2018, 01:21:29 PM »
I am repeating myself but it is pretty common to find transcription errors in hand drawn schematics (like all were decades ago).  Also there may be circuitry not shown off that schematic page limiting base current.
As usual don't ASSume that every schematic is accurate (or reported measurements for that matter).
Last post April 19, 2006, 05:54:16 PM
by henk
Last post July 12, 2006, 05:02:44 AM
by toffifee
Last post August 15, 2012, 06:57:42 AM
by 625uhf
Last post September 13, 2018, 07:09:51 AM
by abbey road d enfer
