Seek schematics / tech info for Orange County Compex
David Kulka
Burbank, California
I'm looking for any schematics or tech info for Orange County version of the Compex. I'm servicing one of the newer versions with redesigned opamp type PCB's and unfortunately the original ADR schematics are totally useless for this version.
I saw a few leads on other threads here but no docs or contact info found so far.
A bit desperate here, and help would be appreciated. Thanks in advance.
Have you seen this and tried the contact?? I know it's old and discussing other units>>>and maybe you already have....
http://www.preservationsound.com/?p=6808
Michael Gillespie & Michael Franzmann
11/09/2014 at 3:46 am
I am the founder of Orange County Electronics and was chief designer and product manager for the units you are discussing.
If anyone is in a real jam, I have all the docs, schematics and parts lists on microfilm.
Michael Gillespie
+204.943.9000
looks like the member here iampoor has reached out....maybe you could get with him and see if he had any luck????
I have the orange County Stressor which I believe uses the same compressor module.
You will find my schematics for the unit below.  Should help.
  • Orange County Comp EQ.pdf
