INA 217 Mic Preamp Circuit
« on: March 07, 2019, 12:26:53 AM »
Hello I'd like to realize some INA217 mic preamps
On the net I found several circuits but I am not sure how they work
Someone can provide me a good tested  schematic?
Matador
Re: INA 217 Mic Preamp Circuit
« Reply #1 on: March 07, 2019, 12:38:17 AM »
The datasheet has everything you need.
« Reply #2 on: March 07, 2019, 01:52:00 AM »
A thing I have not clear it is because some circuits have the OPA 137 and others no
What's the difference?
gyraf
« Reply #3 on: March 07, 2019, 02:24:56 AM »
Start out by reading and understanding the data sheet. As Matador says - it has everything you need to know..
Jakob E.
« Reply #4 on: March 07, 2019, 03:01:01 AM »
Unfortunately I'm not very experienced
iampoor1
« Reply #5 on: March 08, 2019, 07:43:59 AM »
Build the figure 16 circuit.
Harpo
« Reply #6 on: March 08, 2019, 09:35:39 AM »
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.  -Douglas Adams
« Reply #7 on: March 08, 2019, 12:45:55 PM »
In this site it is offered a PCB for this preamplifier, but it doesn't inclde the OPA 137
http://www.bluecomtech.com/Web%20Sites/OSH%20Park/oshpark.com/shared_projects/QbTViZlZ.html
Matador
« Reply #8 on: March 08, 2019, 01:50:07 PM »
If you look at figure 16, it says the OPA137 is part of an 'optional DC control loop'.  It is a DC servo that works to keep the output potential at DC 0V.
Do a Google search for 'dc servo tutorial' to learn more about it.  I found it wasn't needed when I built this circuit in the past.
« Reply #9 on: March 10, 2019, 04:01:25 PM »
« Reply #10 on: March 11, 2019, 01:26:55 AM »
Thank you
« Reply #11 on: March 12, 2019, 01:09:07 PM »
I have found this simpler schematic with THAT1510
Anyone knows if it is possible to add a transformer to the output?
Newmarket
« Reply #12 on: March 13, 2019, 07:09:04 AM »
Of course it's possible . But the questions are why you want to and consequently what is the best way to implement it...
« Reply #13 on: March 13, 2019, 07:23:49 AM »
I want to add the transformer to balance the output ... without complicating the circuit
I'd like to use something not too expensive like OEP A262A2E
Consider I'd use these preamps essentially for external drum recordings
« Last Edit: March 13, 2019, 07:34:34 AM by Liutmod »
Matador
« Reply #14 on: March 13, 2019, 04:21:00 PM »
A DRV134 is a good option.
« Reply #15 on: March 14, 2019, 03:02:32 AM »
I know but I'd prefer to put a  transformer if there are no contraindications
In the output of the THAT1510 (pin 6) may be better to put a capcitor?
john12ax7
« Reply #16 on: March 14, 2019, 04:10:55 AM »
Yes you can put a transformer on the output.  Jensen and Cinemag are good resources for transformer application notes, as there some details that are important.
« Reply #17 on: March 14, 2019, 01:32:19 PM »
Do you think the OEP A262A2E specs are ok for the output of THAT1510?
john12ax7
« Reply #18 on: March 14, 2019, 05:06:26 PM »
It's not the best choice.  The main issue is ICs are generally not good at heavy lifting,  so you would be asking a lot of the 1510 by putting that on its output.  You definitely don't want a step up transformer (1:2), you could wire it 1:1 but you are then still limited  by its inductance.
You could get a  good 1:1 transformer for $30-40.
Edit: if you wanted something inexpensive to try A262A7E would be a better choice.  Though you would still have a good bit of low frequency distortion with these.
« Last Edit: March 14, 2019, 05:29:49 PM by john12ax7 »
« Reply #19 on: March 15, 2019, 01:52:51 AM »
Thank you John. I will follow your advice
Last post November 10, 2010, 06:31:23 AM
by abbey road d enfer
Last post September 27, 2005, 11:27:11 AM
by TedF
Last post January 19, 2011, 01:54:18 PM
by kambo
Last post October 11, 2018, 03:58:17 PM
by squarewave
