how to read old schematic capacitors??
Olegarich
GDIY Supporter
Vilnius_Lithuania
I'm looking for a schematic of an old TV and capacitor are marked traditionally but instead of capacitance value uf, nf or pf - there is 22K, 47K, 10K - jsut like resistors, but those are capacitors and tthey marked like C1 - 10K, C2 - 47K. Why? and how to read that?
The k is still a thousand multiplier, with the base size pF. So 22k is 22000pF, is 22nF. But the surrounding circuitry should tell you what a reasonable value would be.
K most probably means tolerance (10%)
47k is 47pF, 10%
Third number is number of zeroes.
471 is 470pF, 223 is 22000 pF or 22nF and so on.
You are right, I was wrong. If k is marking on the schematic it means x1000.
But I never saw it on a capacitor symbol.
"K" as an indicator of tolerance, same as "R" , "J" , etc,  "is a modern thing" , way back then they were happy just indicating part value, and 20% tolerance was implicit, unless specifically noted otherwise.
10% was above normal and 5% was premium.
1% stuff? only inside Tektronik or Hewlett Packard Lab equipment, go figure.
In a way, a simpler life :)
