TornadoTed
Balanced line level booster
« on: March 09, 2020, 06:46:48 AM »
I have recently bought a Modal Electronics Argon8 and it has a really quiet output, around 20 dB quieter than all my other synths.
I am looking for a simple device that will take a balanced line input, boost it 20 dB with a balanced line output. Something along the lines of a Cloudlifter but for line level. I know I can use a DI and preamp but I have my synths hardwired to my audio interface and it seems overkill to tie up a DI and preamp for the task.
Does anybody have any ideas or solutions?
« Last Edit: March 09, 2020, 08:43:22 AM by TornadoTed »
Giant Wafer Studios
www.giantwafer.com
mjrippe
Re: Balanced line level booster
« Reply #1 on: March 09, 2020, 09:09:28 AM »
If your synth had an unbalanced out (or if you are ok with unbalancing it) you could use a Henry Engineering Matchbox designed to boost -10dB unbalanced signals to +4 balanced.  They are about $25 used and they are stereo.
TornadoTed
« Reply #2 on: March 09, 2020, 10:11:22 AM »
Great suggestion, thank you. I haven't seen those before.
I haven't found any in the UK but it looks like the new Pro version has a switching power supply that will work anywhere in the World.
Giant Wafer Studios
www.giantwafer.com
dmp
« Reply #3 on: March 09, 2020, 10:17:27 AM »
I would contact the manufacturer and ask about it. It would be crazy if they built it without the capability to put out a line level.
Youngwhisk
« Reply #4 on: March 09, 2020, 03:10:28 PM »
I am sure you have read the manual. Does the volume control not bring it up to a usable level?
From the manual:
Line Out
Line level stereo outputs on 1/4” mono/ TS and stereo/TRS jacks. The left jack only will break the stereo circuit and collapse the signal to mono. These outputs can be connected to any line level input for monitoring and recording. The line output is higher quality than the headphone output, so always use it when recording or performing. The Line out level can be adjusted using the ‘Volume’ knob.
Last post October 16, 2006, 05:25:45 PM
by BR
Last post December 06, 2008, 09:51:37 AM
by pucho812
Last post April 04, 2015, 05:31:19 PM
by Monte McGuire
Last post April 03, 2010, 05:03:26 PM
by tv
