3nity
Updating my PC
« on: May 14, 2020, 11:22:19 PM »
Well time came i need to update from pt 7.4 to something more current. So i can use some of the newest plug ins.
I want to upgrade to pt 12 not sure though..maybe switch to digital performer and go with a motu interface.
Right now my setup is a 002r with a Intel celeron 4. Im thinking i5 9700 with a msi motherboard with hdmi output...
Not sure though..what you guys suggests?
Life is a path, death the destination.
Rocinante
Re: Updating my PC
« Reply #1 on: May 15, 2020, 07:30:21 PM »
Member Whoops has a thread about troubleshooting the latest motherboards and thunderbolt capability that is worth reading. MOTU's work with PT12 perfectly. They work with any DAW.  You don't need to use thunderbolt as they also have usb-3 which is more than capable of handling whatever you are going to throw at it. Moving from an 002 I am assuming you aren't doing big projects, but even if you do they are expandable and the avb network is impeccable. I have 2 MOTU systems. One for the studio that uses the motu pci-424 card, with 2 x HD192's and a 2408 mklll; that is just a bridge for the apogee ad16x.
For location recording I have the latest gen MOTU ultralite
Eventually I'll pick up the  16A  and 16D.
If there's a harder way to do this, I haven't found it yet.
john12ax7
Re: Updating my PC
« Reply #2 on: May 16, 2020, 03:44:48 PM »
I would say get at least an i7 if possible.
3nity
Re: Updating my PC
« Reply #3 on: May 26, 2020, 08:25:38 PM »
Ill update to an I7 !!
Whoops
Re: Updating my PC
« Reply #4 on: May 31, 2020, 08:35:43 PM »
Hi 3nity, how are you mate?
I recently built a new PC,
check out this thread:
https://groupdiy.com/index.php?topic=74862.0
These are my components:
Processor Intel Core i9-9900K Octa-Core 3.6GHz c/ Turbo 5.0GHz 16MB Skt1151
Motherboard GIGABYTE - MB Z390 DESIGNARE 1151 ATX 4XDDR4
RAM Corsair Vengeance LPX 32GB (2x16GB) DDR4-3200MHz CL16
Water Cooler CPU Corsair Hydro Series H100x 240mm
PSU Corsair RM Series RM650 (2019) 80+ Gold Full Modular
SSD M.2 2280 Samsung 970 Evo Plus 500GB MLC V-NAND NVMe
ATX Sharkoon Pure Steel USB 3.0 com white
analag
Re: Updating my PC New
« Reply #5 on: June 12, 2020, 03:10:28 AM »
Asrock Steel Legend X570
Asrock TB 3 aic r2.0
Ryzen  7 3700X
G.SKILL Trident Z RGB (For AMD) 32GB (2 x 16GB)
Sabrent Rocket NVME 1T OS
Sabrent Rocket NVME 1T data
1T SSD  audio
EVGA SuperNOVA 750 G+, 80 Plus Gold 750W, Fully Modular, FDB Fan
etc.
Custom water cooled...rubber hose so I can run glycol based coolant
Audio is stored and backed up on USB/ SSD's
LG 34" monitor
Presonus Quantum Thunderbolt...record/ monitor
Focusrite Clarett 8pre USB....playback
Later I can get the Ryzen 9 3950X 16core if I ever need to upgrade this beast!
« Last Edit: June 12, 2020, 08:00:20 AM by analag »
Audio engineering suffers from misinformation, disinformation, and downright lying more than most fields of endeavour.
Last post November 28, 2006, 09:50:11 AM
by Svart
