Martan
Adding a DI through for a DI input
« on: August 08, 2020, 01:13:40 PM »
Hi all,
I am building a couple of tube preamps based on Drip boards (V72/REDD47). For the DI input, can I just run straight wires from the input jack to an output jack for a DI through? Will it have consequences to the preamp circuit (loading, etc.)? I want to record bass DI through the REDD47 but would love to send the signal to a B15 amp I built as well.
Marty
Re: Adding a DI through for a DI input
« Reply #1 on: August 08, 2020, 02:07:18 PM »
Your ground/float options are probably the most critical thing.  Insulated jacks frequently used for that reason.
Martan
« Reply #2 on: August 10, 2020, 12:43:11 PM »
Thank you for your reply. Does this mean if I put ground lift options on the preamp and there is one on the amplifier for the bass then I just look for the least noisy option?
Would I want separate ground lift for the preamp on both the xlr out and the DI through?
Thanks again,
Marty
Last post November 27, 2004, 07:14:20 PM
by Flatpicker
Last post January 04, 2006, 12:59:54 PM
by digichild
Last post January 06, 2006, 09:23:40 AM
by MikoKensington
Last post February 23, 2009, 10:16:09 AM
by NewYorkDave
