I recently built this phone preamp:
http://www225.pair.com/audio/waltzingbear/Schematics/Pacific%20Pecorders%20&%20Engineering/TX990-Schematic.pdfThe only difference in the P.S. is that the power transformer in the schematic calls for a grounded core and my toroidal transformer doesn't have a core tap.
What I am experiencing is intermittent gound-loopish noise. 120Hz and harmonics @ ~ -65dB.
What does NOT affect it:
-It is not induced emi from other units in the rack - the position of the unit in space doesn't change anything.
-It is not coming from the turntable or the first stage - the volume control between the first and second stages doesn't affect it.
-Galvanically isolating the outputs also doesn't do anything.
-Isolating from the rack rails doesn't do anything.
What DOES affect it:
-Where the preamp is plugged in - everything in the studio is run off of a single outlet - changing where the preamp is plugged in affects the likelihood of the noise appearing.
-Turning off other units in the system - specifically, the power amplifier and the console power supply.
Any ideas on where to look?
Ben
