[quote author="Harpo"]congrats :thumb:
Did you end up with single rail voltage for headphone amp, relais and led ?[/quote]
I used a 2x 15v transformer, 1 output is used for the relays and leds and the other one is used for the headphone amp.
The relays are just activated when you push a button for let's say, mute, it's in rest when not pressed.
Ofcourse the input realys are activated with active input and when switched to monitor B it's also activated but most relays are not powered in normal use, even the relays for the 2 color leds are just in use when a button is pushed.
As you can see all audio signal relays are as close to the XLR's as possible to keep the wires as short as possible and to avoid the audio being crossed by a voltage line, even the relayscoils are as far away as possible.
The relays in front are for switching the leds and the voltage lines for the headphone amp and from one board to the other are mounted on the bottom of the case just behind the frontpanel.
The headphone amp is a single 5532 opamp powered with about 2x7.5v with a resistor divider network and works perfectly!
The only thing i have to change is the level pot, it's on the output right now and i used a log pot which should be a rev log or lin pot, now only the last part of the pot is taking care of the level making it hard to get the right level.
Maybe i'll also put the pot on the input instead of the output because when the input is loud i get a slightly distorted sound, the output itself is very LOUD and clean so that is not the problem.
Input 3 has a 12steps attenuator (unbalanced) connected to the input for tuning, this input i use directly from the soundcard ouput for mastering.
For the rest i'm really happpy with the result, it works great, sounds great (doesn't sound at all that is..) and it looks even way better then i expected it to look!
I will post some inside pics and clearer pics of the frontpanel later on.
