more info:
"These amps were NEVER loaded by 200 ohms. They were built out to 200 ohms which is a big difference.
Mostly, the load on them was bridging. Worst case would be if a fader was off, then they'd see the build out resistor and the 200 ohm of the fader. So, a lowish load in that case but they're OFF...so who cares
The whole idea was that the valve saw as little a load as practical."
"Upon reflection: If you can swing it, spend the extra $30 for the Hi-N. Cinemag. In the scheme of your total parts cost, it's a fraction.
I'd say my new transformer sounds closer to that one than it does to the 50-50
I know you're using a PCB so it's a bit more complicated but there are other things too that affect the tone of pre amps. Power Supply topology, component choices, layout, tubes, slight tweaks in H.T. or bias, different forms of bias, Feedback (don't use too much if you can help it)... etc...
The Cinemags handle a ton on signal and, in typical level use, are very linear. Same for the CMMI-7C input if you have a stepped attenuator before it. You won't be hearing much iron saturation. The differences will be tonal shifts to various degress. I've heard as much of a difference in a pre amp by changing the brand and voltage of a cathode bypass cap."
"Dear Mr. Normal
(John Lennon called their first engineer Norman Smith "Normal" so it's kinda, sorta apt.
None of the circuits in the desk operated into a 200 ohm load. Each device 'presented' 200 ohms to the following circuit. Except the oscillator which WAS loaded with 200.
Internal output impedance of the REDD47 (including the DCR of the original transformers) was about 50 ohms. A 150 ohm resistor was added as 'build out' to bring it to 200 ohms. Depended on what was following the unit as to what the actual load was. Worst case: A following 200 ohm "T" attenuator or fader turned all the way off would load the amp with 200. Add this 200 to the 150 build out so, worst case load was 350 ohms. Again, this was when the amp was turned off. Most times the amp is bridged by a higher load.
Not sure which spec sheet you're referring to, I have them all and there are quite a few but a 200 load on an original "built out" REDD47 would result in 6dB loss in gain.
Edit: which brings me back to a point earlier: measure the internal output impedance of your REDD47 and calculate backwards and you'll see that the anode source impedance to the transformer is WAY lower than 20+ K."
WB
RDH4 pg 519>
"loading results in higher wave distortion and secondary loading also results in higher transformer distortion, loading is generally undesirable, although unavoidable in some applications"
the effective load on the valve is given by R-L = R1 + R2/T*2, where
R1 = resistance shunted across secondary
R2 = resistance shunted across secondary
T = N2/N1 = turns ratio
notice that the turns ratio is backwards from normal, ie, a 7:1 would be 1:7 in the formula
