I finished mine yesterday, then listened to many genres of program material through it on numerous settings for hours while cleaning up my build mess and setting up to shoot photos of it, and share the same sentiment as
@JMan with feeling like a kid on Christmas. This thing rips, is extremely quiet at idle, and I’m surprised that the thread isn’t 100+ pages by now. It’s affordable, easy to follow, easy to calibrate, original, modern, and was a pure joy for me to build. It sounds so good running it transformerless that in hindsight I wish I’d have omitted the input trans option and saved some $$ and wiring time.
It’s been a long time since I’ve hardwired an entire build without one breakaway connector, so I was very happy to fire it up and have every voltage test point measure spot on. A +4dBu sweep at unity gain was dead flat from 20Hz to 25kHz on both channels. The tube balance calibration measured less than 1mV on each channel (-60 and -62dBu) with the NOS GE 6SK7 steel tubes. I also bought extra bundles of NOS RCA (also steel), Sylvania JAN, and Hit-Ray (both glass), but didn’t feel the urge to swap out the GE’s. The AC-DC power adapter is a TDK-Lambda DTM65PW360C that I bought a couple of new on eBay. The datasheet for it listed the model of the Kycon connector, so sourcing the correct chassis power inlet was easy. I can also confirm that you can use any brightness LED that you want for the GR meters and it doesn’t affect the metering; just adjust the 4.7k resistor values to taste (R4, 7, 10, 13, 16, and 19). I used super bright and dumbed them way down, with the added benefit of drawing less current from the PSU. I sent the 25.3-ish volt power for them out to a breadboard and worked all that out beforehand. Each color change ended up with a different value for them to all match in brightness, as expected.
I’ve been wanting to design a front panel inspired by a vintage HH Scott integrated amp that I read about many years ago in a tube amp magazine, with a gold faceplate and slide switches, and this project felt like the perfect fit. I did a fair amount of CAD work to lay out the symmetry and figure out the side chain mounting panel (to both conceal the hardware and buy myself some space for where I wanted to mount High-Low switches), GR PCB locations, power switch plate, and case layout. I wanted the GR LED’s to be on the same centerline as the slide and rotary switches, so that meant bending an offset on the ones for Channel 2. I drew the LED with the offset in CAD, then printed it and taped it to a wood block with a cavity for the LED to sit in and bent them. It worked like a charm when installing the meter PCB’s. I clamped the face of the front panel to a piece of 4mm aluminum I had laying around, placed all the LED’s in the PCB’s, mounted the boards to the standoffs, used a hex driver to reach in and push each down until they hit the 4mm panel, then soldered them. To clean up the look of the gap through the power switch hole and keep any light emitted from the backside of the meters from shining through it, I cut a scrap piece of tool box drawer liner, used a leather punch to make the holes for it to slide over the standoffs, cut a slit in it, then affixed it to the front panel with E6000. In case of future surgery or potential initial troubleshooting with everything hardwired, I wired it with everything coming up from the bottom to the controls so the front panel can be unbolted and rotated down flat on the table.
Thank you for the boards
@scott2000, Heikki for the wonderful project, and everyone else who contributed useful information in this thread!
