Deacy amp transformers
You're right.
So the negative of the battery must not be connected to "ground". Because it's a battery, both + and - are floating. At least in the one without the cabinet it uses that one side of the speaker as "ground". And because the input is capacitor coupled, it still works. That was done so that the sleeves of the jacks are connected together like a typical guitar pedal.
Typically, both the treble booster and the amp are battery powered. The ground is a bit strange since the transistors are PNP, so the ground should be positive, and the power supply negative, like in the KAT schematic.
So where are these "off-the-shelf transformers"?
In the non-cabinet version https://doxyworld.com/images/documents/supersonic_doxy_spec.pdf
The cabinet version specifications:
https://www.doxyworld.com/images/documents/supersonic_pro_spec.pdf
says the transformers are "hand-wound bespoke replicas of the original Supersonic transformers" which sounds like BS to me.
As far as I know, the person making them has one of the original radios, so they can make clones relatively easily. Are you suggesting that both versions use the same transformers?
If the off-the-shelf ones have the right taps, that's not really going to be much different. If you can find those, that's 90% what you need to make one a legit one.
Indeed. And that's one of the reasons I posted. I hoped someone might know them since they exist.
The KAT transformer specs are a bit misleading now, since they for the kit only. On the other hand, they can't be totally off.
What do we actually know about the transformers?
The interstage ratio is 2:1 (page 116)
On page 115 we can see:
Since the ratio is 2:1, so 200:50-50 are probably DC resistances (not impedances). That almost matches KAT's 230:106. Also, since 200:100 = 2:1, both windings are made with the same wire gauge.
I'll try to find a similar Hammond one.
Now the output.
The impedances are 140 CT:35 (page 117), so the ratio is 2:1.
On page 115 we see:
DC resistances (presumably) 2-2.5-2.5-2:X, assuming there are only 2 windings. So the full ratio is 4-5-5-4:9.
To sum up, we're looking for:
Interstage: 2:1, RDC=200:100
Output: 4-5-5-4:9, RDC=9-?, Z=140CT:35
Or tell me where I made a mistake.
Impedance ratio.
No I think those are actually impedances.
I think those are actual impedances. With 9V, you need low impedance to get enough current to make a decent amount of power. The speaker is probably 4 ohms so what it's connected to has to be similar. But it's not trivial to figure out what that impedance is because, with the center tap grounded, only one transistor is pumping current into one half. But the other tap is magnetically coupled to the core. So I think it's 5 ohms but not sure. I'm not a magnetics guy.
But my guess would be that the OT is an impedance ratio of 9:4.5 / turns ratio of 1.4:1.
So they're trying to pump as much current through it as possible. But inductance is very low so it's low frequency response is probably really bad. Thus the two feedback paths around the output.
Hammond isn't going to have anything like 1.4:1 with 3 taps. That's wacky. That's why I asked why the DoxyWorld specs say "off-the-shelf". Find out what shelf they're getting theirs from.
Impedance ratio.
Turns ratio:
So 200:50-50 are not impedances.
2-2.5-2.5-2 can't be. As I wrote, the impedances are:
It's 16 Ohm. The KAT-Celestion speaker replica:
so what it's connected to has to be similar. But it's not trivial to figure out what that impedance is because, with the centre tap grounded, only one transistor is pumping current into one half.
I don't thin that's accurate. Note that it's the inner tap, not the outer one, the collectors are not grounded, therefore both transistor are still outputting fine. One of the transistors is getting an extra 4.7k resistor between the base and ground, and not getting the feedback (right?).
EDIT: typo
Turns ratio:
Ok. I guess you're right.
Where is this PR80 manual that you're referring to? Did you post a link for that already? If not please do.
But a 16 ohm speaker on windings with 5 ohms of DCR is pretty strange.
EDIT: typo
I think it's accurate. The transistors are going to be biased so that they're just barely on. When signal is present, the transistors are going to alternate between being more or less on and off. When one is on, the other has to be off. Since the center tap is connected to ground, that current is only going through one half of the primary. But that's not a terribly important detail. As for feedback, if there is a negative swing on a base, that will turn on the transistor which will deliver current to the transformer and into ground. That will cause a positive voltage to develop at the inner tap which, through the 4.7k, will provide negative feedback.
I thought you had access to the radiomuseum manual. Long time ago someone posted this:
Wayback Machine
Wayback Machine
Wayback Machine
Wayback Machine
Wayback Machine
Wayback Machine
Wayback Machine
Wayback Machine
Wayback Machine
Wayback Machine
Wayback Machine
How do we know that the RDC of the secondary is 5 Ohm?
Fair enough. I'll have to think more about it. BTW page 115 has some voltages marked.
I do but that's not what's on the site. It has a completely different document. The circuit seems to be the same but the presentation is completely different. The one you just posted does not look like a manual. It appears to be a section of some kind of third-party service manual. But it's better than the one on radiomuseum.
Because the speaker is connected across 2.5+2.5. But that's not the proper DCR because the tap can source / sink current from the ends of the winding as well. And the center tap is low Z. And according to your "manual" the speaker is "30-40" ohms. So maybe a DCR of an ohm or two isn't a big deal. Again, in general it's not terribly important.
Does the one from radio museum have more info about the transformers?
Makes sense.
Now, more food for thought for the off-the-shelf doxy:
And there goes the feedback to the emitter of X7 (AC126). Now it's connected through C14 to ground.
The transformer just got simpler. Now we have an autotransformer with 4 taps and RDCs 2-2.5-2.
No.
Wow. That's super interesting. I wonder how the DoxyWorld guy would have known to do that. He must have had the inside track. Or maybe he had access to a KAT replica.
Grounding that feedback cap removed the negative feedback and bypassed the emitter resistor of the interstage transistor. With one tiny inexpensive piece of bus wire, the gain is double boosted! John Deacon was quite the hacker. I'm impressed. Well played sir.
That opens the door. The difference between the inner and outer windings is really not that much. You probably could just use a transformer with two CT windings that are the same. Like Xicon 42TM030-RC which is $3 USD on Mouser. It's primary and secondary are 100 ohms so 200 total vs 140. That's good enough for government work. And the description you posted originally said the transformers were badly imbalanced so if there's a little difference between primary and secondary that's what you want anyway.
Shouldn't I use a 1.6:1 (2+2.5+2:2.5)? It's the same wire, so RDC ~ wire length ~ number of turns? So maybe
42TM031-RC?
Unfortunately, only the cheaper Doxy has that wire. I wasn't able to confirm it's existence on the original Deacy or the Doxy Pro. But I found some pictures of the original transformers and the replicas. They have 7 taps. It seems the off-the-shelf-transfomers version takes some shortcuts.
Another OT from the other side:
EDIT: added a picture
Any news on the transformers? I would want to try to build the Deacy since they discontinued the KAT kit.
In the end, I bought the kit, so I've got the transformers. I'll be happy to take some measurements, but apart from DC resistance, I don't know what to do. I don't have an inductance meter.
I have been collecting some transistor to make a couple of these for awhile. The thing is with any of this old stuff is that anything made today is pretty far off what was made back then. I am considering using the Hammond 109G for the interstage and 109E for the output. Yeah I know 3.2 output, so use a 4ohm speaker. Most of these Hammonds are old RCA designs so they would be pretty classic in nature. Ok sure higher grade copper than what was used back then but use a bit of the old stuff with the new stuff, try some different values and get something close.
Ok my 2 cents on the design:
R11/R13 create the bias for the output. Depending on the VBE of the transistor you may want to change those or use a pot to bias the output. If me I would make R11 47R, R13 a 10ohm pot to dial it in.
C6/R14 is a snubber for overshoot of the output, I would make the thing send a 1K-10KHz square wave through and try different values to get a clean (or dirty) signal out.
R12 is a slight feedback circuit probably because the output transformer is not balanced. Anyone who have worked with famous designers know that balancing a PP output requires more work and money. These guys would be asked to redesign for cost basis. That resistor might be better off being like a 1M pot that you could vary and get some balance out of the damn thing.
It's too bad there isn't voltages on any of these to see where they fall and aid in changing values.
I just traced the KAT version:
Unsurprisingly, it's almost the same as the original PR80 schematic that I linked here.
Wayback Machine
The tone circuit is missing, the polarity of C4 is flipped (according to the schematic, but not to the pictures of the real PR80 circuit), and some values are slightly different.
I can take some measurements. Just let me know which voltages you need, on the KAT schematic.
EDIT: PR80 schematic
EDIT: comment about polarity
rsasgtr,
What is the DC voltage on R10 and R11? That will give us a better idea of what kind of interstage and output transformer is required.
Isn't there a resistor between C8 and Q2 emitter? Actually looks pretty different from the KAT schematic.
Gordon
Given 7.43 V from batteries, the voltages are: Q2 emitter (R10): 6.56 V, Q3 emitter (R11): 7.41 V.
I also checked RV1: 7.37 V.
Yes, there isn't.
There are 3 schematics in this thread. The first one is of an earlier KAT Deacy-like amp (we should ignore this one). The second one is of the PR80 radio from which the original Deacy got it's PCB. The third one is of the KAT Deacy replica kit, which is the one I traced, and is supposed to be the exact copy of the Deacy.
