[silent:arts]
how would you do it ?
Rat's nest[silent:arts] said:how would you do it ?
Oh...but we can...and we will... ;Ddandeurloo said:...If we could all only have a API console. ;D
[silent:arts] said:
you have given the answer alreadyBiasrocks said:...
I realize that these probably see little use, but why not include them.
I apologize too as I'm way late to this party. Busy with other things.Biasrocks said:[silent:arts] said:
I apologize if this has been discussed.
Why no connections for the Gain Trim and -2 outputs?
Mark
Volker, I will put some things together. After a little more thought, I believe the "console" backplanes should be a separate and different beast(s). I also think an important goal is to utilize the same enclosure for each PCB/task. Different boards will be no problem.[silent:arts] said:??? ???
mail me a draft drawing what you exactly mean.
I will have a look what I can implement.
Hah. I type too slow.Cpartipilo said:I say keep it simple, super cheap and let people use a patch bay!
If you want something more complex i'm sure a new backplane could be made. After the initial batch then the guys might be able to design different boards for the same case with different options.
For the 1st project i'd say keep it as simple as possible.
jsteiger said:Also, on my board, I don't use the mounting screws for any of my 500 modules. If I want a 560 on the snare top instead of a 550, quick hot swap the modules and your are done. Or with no eq, I need to insert a jumper card.
which is no problem.jsteiger said:Yes. All of these thoughts would be new a completely separate boards.
Funny(not really) how you don't hear much about Ford these days but GM is still on the verge of going under. We must let them go. They should not run that company like Government. I am tired of all this bailout BS. Nobody is bailing me out of anything.dandeurloo said:...Is any worried that to much swapping in and out may wear down the conections on the cards?
Also, I agree if the metal work can be the same and swapping out cards foe future expansion or new design that could use the same metal work to work on a mixer of sorts would be a great idea. Help keep cost down like Ford vs. GMC.
jsteiger said:If I want a 560 on the snare top instead of a 550, quick hot swap the modules and your are done.
