Arrigotti
I am using this PT:
http://rocky.digikey.com/WebLib/Amveco-Talema/Web%20Data/62000%20Series%20Low%20Profile%20Miniature%20Transformers.pdf
I get how to hook up the primaries for 115V, and I understand how to wire the secondaries in series, but my question is how to hook all of that to the PCB.
Do the 2 center wires on the secondary constitute a center tap and are therefore considered the common or 0 volts?
On MNats PCB's that I have, there is a section labeled 24-0-24. I am assuming that the outer wires (green and blue in this case) of the secondaries go to the 24 volts. It is the 0 that I am confused about.
