Andy Peters
JohnRoberts said:New question.. Do you feel the 5V and 500ma capability are safe? As in safe to depend upon for future products. 5V is already getting long in the tooth for digital logic, so I would expect some pressure to move USB or a USB like interface to 3.3V or lower.
USB 3.0 allows 900 mA, still at a nominal 5V but VBUS is allowed to go down to 4V (and up to 5.25V).
Sure, pretty much nothing digital these days runs on 5V, but if USB changed to a 3.3V supply then they'd have to at least change the connector (much the same way that PCI slots are keyed to indicate 5V-, 5V and 3.3V or 3.3V-only capability). Also, since voltage drop across the cable length is a concern, a lower voltage could be a problem. Anyways, it's easy enough to put a switcher (or LDO) in the product which gives the needed, and regulated, voltages.
-a
