Sold 1976 Audio Developments AD-031 channel strips
envelope
Canada
Audio Developments AD-031 "Micro Mixer" channel strips for sale:
They fall into the vintage 70's category of high end british gear used extensively by BBC along with (neve, cadac, audix, calrec, emi)
functionally serviced only with a few caps replaced, and I have installed new faders.
Listing is for the professionally serviced modules only. The pictured +24VDC PSU and 'bench test' WIRING harness are not included.
The insert is presently bypassed with a wired jumper.
I have racked these in the past using the Aux send as a direct output.
On the general schematic there are 2 areas in dotted lines that do not exist in these particular channels, labelled (Hi-PassFilter) and (PFL)
Pinout
Pin 1 Ground
Pin 2 +24VDC
Pin 3 Input +
Pin 4 +48VDC
Pin 5 Input -
Pin 6 Insert point (tied to pin 10)
Pin 7 Aux send
Pin 8 A bus (left)
Pin 9 B bus (right)
Pin 10 Insert point (tied to pin 6)
$200 USD each 4 available. PayPal in USD
shipping in canada is $50 for any quantity
shipping to USA in $75 for any quantity
I can send you the manual, via PDF, if you send me your eMail
Hello!
Before I add this as a project to my bench, would the PSU hookup and wiring harness be something conventional enough there’s a modular rack-mount design here i could map to?
Thanks, i’d definitely like to add some channel strips to my setup without needing the size and space of a full console.
Hello!
I have no idea if any racking materials would be available here.
Hi envelope!
I went out back with my morning coffee today, and ran into a man with the loveliest Audio Development mixers and asked him about racking these, as it was on my mind too.
