JW
I replaced some 15000uf filter caps in my mixer's power supply with 22000uF. The rest of the power supply was recapped and working fine prior to this. So it was the only operation I did before I loaded it down with one channel and two buss channels and powered up. I get a blown main fuse .
I know the extra inrush current can cause fuses to blow, but question is how long does this take? Like 2 or 3 seconds? Or say 30 seconds? Because I powered it on, and it took about 30 seconds to get over to the board, arm input channel and buss and only when I armed the channels and pulled up the faders did the fuse blow. The seeming simultaneousnous of arming the channels (i.e. completing the circuit that powers the channel arm bulb) makes me wonder if I didn't pull a wire or something in the meter lights circuit. I wouldn't think that would cause the power supply mains fuse to blow though. Maybe wrong.
But anyhow, main question is, how long would it generally take to blow a fuse if my filter caps are too large? Upping from 15000 to 22000 I thought would be okay. It's a little less than 50% larger and convenient in that they have the same diameter.
