25 VU-meters for 20 Euros "buy it now" @ evilBay
Look, guys, I´ve bought 25 also, and there is still one more lot:
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&category=8251&item=5708207973
I´ve bought them some weeks ago.
Can someone figure out if we can use them for an 1176 e.g. ?
I´ve just started a 1176...
Jürgen
Man, if it´s a VU, yes, it can be used anywere a VU is needed. 1176, LA2a, etc...
BUT, not in the SSL, I think. Maybe with a little mods.
[quote author="kubi"]Michael, that's enough meters for 40 x 1176 or LA2A :grin: :grin: :grin:
[/quote]
I might need them to build a meterbridge for my console, it had RTW meters, but the control electronic is lost :sad:
Though 40 LA2As are tempting too :grin: :grin:
But there is another lot!
Michael
They look very simular to that:
http://www.rs-components.com then search for 348-8380
For the 1176 you will need the bigger one:
I don´t care about the size, the´re cheap.
I just wanted to know if someone found out or can find out if there is a need of change (a resistor e.g.) in the 1176 design.
Frank ? Do you have experiences ?
Jürgen
Yes I did.
I m not worry about the scale but about the specifications.
Do have all VU meters the same internal resistor ?
Do they all need the same driver circuits ?
Did you test it or do you suggest ?
Don´t know how to explain it better...
The 1176 meter driver circuit can be adjusted in a wide range, so it's easy to make fit to different meters. I have used it with a few different meters.
But talking about mA meters, real VU meters have all the same internal resistor.
But these meters on Ebay ain't real VU meters.
I think that a standard "real VU" raw specs is something like 650uA fsd, used with a 3.6K resistor in series, and has internal selenium or germanium bridge rectifier.
Jakob E.
