2520 follower - unity gain stable?
TomWaterman
The Shire, UK
Hi sorry to post such a trivial question but have tried searching, no time to lash one on the bench to see.
Is the API2520 unity gain stable in follower config? Want to use one at the input of a compressor circuit.
If not, will external compensation sort it out? Like an Rf and cap in parallel?
Cheers Tom
Probably not. Amplifiers are (were) EXPENSIVE!! Why would you use one and not take gain?
Wire it for 1:10 gain and put 10:1 passive divider in front.
Good points, I think I can go with the 5087/5088 buffer circuit similar to the 550A one...
Perhaps I can run it at some gain and use a step down input transformer... although I already have a 1:1 for here.
Cheers Tom
Transformer has limited frequency response (200Hz-10KHz = $3, 10Hz-100KHz = $$$) and will not have more than medium-high input impedance.
50K to 5K divider right at the opamp pin is 50K in and flat from DC to 1MHz. 500K:50K will be flat from zero to 100KHz. Costs $0.24.
Transformer adds galvanic isolation.... but that need had not been mentioned. If buffer and compressor are used-together, should not be needed?
There are of course many ways to skin cats. Or fish: a Sushi Artist twirls foot-long $300 blades to trim shrimp, but for the customers' entertainment not because it works better than a well-sharpened dollar paring knife.
