EthanSpaulding
The 1M master volume of the 2204 preamp is high level. It will drive the 50W power section beyond clipping. Notice in the DSL40C schematic you have two separate voltage dividers that drops the signal to FX level. First you have the R46 560k dropper into the 500k (two 1M VR1 and VR2 in parallel) and then the 330k 100k voltage divider (R40 R44) just before the IC1b FX Send buffer. IC1A is your Return make-up gain, and you can't bypass that. So, your preamp will need to be padded down. That will be cool anyway as you may want to stick a reverb or delay between your preamp and the return of the DSL40c.
Doing a separate 1M master volume without a dropper may be cool as well. Some power amps need a higher level output- the VHT/Fryette power amps for instance don't make full power at FX send levels, but that is actually pretty rare to not take FX level input to a power amp.
470k into a 50k master volume is about right to get a 2204 preamp to FX level output. It will depend slightly on your B+, but those are tested and proven values. Ideally you want an output impedance of less than 4.7k so you can drive a 40 foot cable of 2nF cable capacitance to and from your pedal board. The 50k master volume will let you down in that case
