rascalseven
I have a couple of 3630's modded with Butta's mod at my studio. I still get the occasional odd look from visiting engineers -- you know, that "you've got TWO Alesis 3630's in your rack?" look (which seem out of place alongside Neve 1084's and 1090's, API 312's, Drawmer, Vintage Design, etc.), and they're always shocked by how good they are when they finally get around to pluggin in to them.
I considered the Black Lion mod (bought the info from him, in fact), but most of the 'mod' was just replacing carbon comp resistors with 1% metal film and replacing ceramic caps with mica. There was very little actual circuit mod as I recall (and I did try the IC's he recommends, but they just had a stark, hard character to them... didn't feel as musical as TL074's or MC33079's that I tried as well). I went with the 33079's.
So in a nutshell I modified the power supply per Butta's direction, swapped the quad IC's to 33079's, and I changed the timing cap for the 'peak' function to 1/10th the original value (for faster response time capability). My units had rev.D boards, so the 1uF timing cap was already on the 2252 (necessary!).
I didn't replace the 2150 VCA's.
I love to use them in peak mode. They're wonderful now, even (especially?) under heavy reduction -- like -20dB. My one gripe is that they can't push much level before crapping out (audible 'snap' on transients at higher output levels), so I generally have to print a little low on the output to keep it sounding nice. I keep thinking I'll get around to adding a simple balancing stage on the output to increase my overall output level, but just haven't got around to it yet.
JC
JC
