supiarmando
Active member
Are there still some PCBs available? I would like to build a stereo version!
sedit1 said:Hi, I need some help
I have some gain problems in my unit, I cheked the previous posts concerning about gainloss but didn't help.
So when the unit is bypassed the gain is normal but when I put the eq on the gain drops about 10db's, it's the same with both channels and it doesnt matter if i use balanced or unbalanced jumpers.
I have a stepped version using harpos xls values and the only thing different is that I'm using green pre psu with +-15v rails.
I just have cheked all my caps, they are the right value no errors there, also cheked solder bridges, all fine.
And measured all the ic pins and +-15v were on the right spots, I'm using JRC 5532d/5534d's
Do you have any pointers that I should check?
Edit...I also checked all the resistors with colour charts, all fine there and measured the ic:s hey were fine also.
So I'm litlebit confused and I was thinking that did I made some mistake using the rotary switches? I used Harpos xls v1 to calculate the pot values(no parallel resistor), I used 11 step lorlins and the center is normal 56k2 the rest of the build is done exactly by the bom. Did I made somekind of mistake, do I need to change some other parts to make the switched version to work normally?
sedit1 said:Thanks good advice!
I triple cheked the resistors but nothing. Everything correct. Here's two pictures if you can see something that I don't.
peterc said:Sedit1
Did you actually measure the resistors suggested above? I know I have a batch of 1% resistors where the 100k looks exactly like a 10k, i.e. the red stripe looks like an orange stripe and vice versa......
Peter
sedit1 said:peterc said:Sedit1
Peter
Thanks Peter, yes I measured them twice and were hoping that that would have been the solution because thats the most obvious, but no.
Whoops said:sedit1 said:peterc said:Sedit1
Peter
Hard to understand, its strange that its the same in both channels.
You should do a signal tracer cable, and follow the schematic, tracing the circuit and figure out at which point does the sound drop.
I would also guess its a wrong resistor value on the same place in both channels
If it sounds good (read linear response) and no gain loss when bypassed, this will not be in the input stage or band stages.sedit1 said:What could possibly cause the gainloss? Just cheked the gainloss is 14db's. Otherwise everything works great and the sound is good.
Harpo said:If it sounds good (read linear response) and no gain loss when bypassed, this will not be in the input stage or band stages.sedit1 said:What could possibly cause the gainloss? Just cheked the gainloss is 14db's. Otherwise everything works great and the sound is good.
Double check/measure the voltage divider R23 / R24 and double check the wiring and parts values of the summing resistors at your stepped gain switches.
Just to make sure, resistance between opamp-out in the freq.band stages (U1,U2,U3 pins 1 and 7) and summing node (U5 pin 2) is varying between 31K6 and 100K with R30 being 56K2 ?sedit1 said:cheked wiring+summing resistors from the stepped switches all ok there. 36k5 going to sum and 100k/wiper going to opamps (using 11 steps +-5db configuration).
Harpo said:Just to make sure, resistance between opamp-out in the freq.band stages (U1,U2,U3 pins 1 and 7) and summing node (U5 pin 2) is varying between 31K6 and 100K with R30 being 56K2 ?sedit1 said:cheked wiring+summing resistors from the stepped switches all ok there. 36k5 going to sum and 100k/wiper going to opamps (using 11 steps +-5db configuration).
