Script said:
Never had my hands on any. The SOS article said good for mastering but probably not for stereo material, which leaves Mid/Side processing.
I use the Night Eq for mastering for many 13 years now, used the hardware unit for around 5 years, but after that I just use the Maag plugin version because I can automate it so it's more flexible,has zero hiss and does exactly what I was doing in the hardware unit.
I still have a DIY version of this, that I prefer to the original unit since it has center detent pots.
electrog said:
There were two versions of this eq available - the standard 1u version and another that, I assume, was aimed at mastering. This was in 2u format and had concentric stepped switches for boost/cut with a pot in the center for fine adjust.
Yes there were 2 hardware units, although I really don't know if they were from the same company or different companies, although they seem to be based in the same circuit and layout.
The 1U unit was branded "N Nightpro"model EQ3-D, it used Pots without center detent, it seems to have come in 3 different colours, Blue, Black and some greyish/Blueish:
Then there was a 2U unit branded "NTI" model EQ3 and has written "High Definition Audio" "Sound Enhancement System", it used Stepped grayhill switches and had Dual PSU's and shielding between channels probably to reduce the crosstalk between L and R, they seem to have come in 2 different colours, Blue and Black:
I had the NightPro 1U unit and used that extensively but never seen or used the NTI unit in any studio or country I worked with.
I don't know if there was any relation with Nightpro company and NTI, the product was obviously related, if anyone has any info please let us know.
A also a nice curiosity is the this EQ was never called the "Night EQ" it was always model EQ3. But is seems people started call it the Night EQ over the years, that makes me think also the Nightpro unit was much more widespread than the NTI unit.
