We have discussed using SmPS for heaters a couple of times in the past. I have now reached th point where I use them all the time heaters. The make I use is MeanWell. THey have a wide range of 12V PSUs from a few watts up to hundreds. Most of their range has what is called hiccup mode short circuit current limiting which is designed to power up into difficult capacative loads but also works well for cold heaters. Even so you I have found you need to rate the SPMS at twice the heater current to ensure it will always fire up. However, they are so small and cost effective this is not a disadvantage. From the technical standpoint, I have found these supplies create much less interference than their linear equivalents.BluegrassDan said:Please tell me more...
