4 pole/4position rotary switch
Leslie West
i am searching for a 4 pole/4position rotary switch for a NYDs like summing routing....
Anyone knows a good (because the signal goes through) and cheap one?
Make before break is better, or?
Thanks in advance
Leslie...
I don't know where you are, but in Europe switches like that are quite rare. It would be a lot easier to get a 6-pole 4 position switch (two 4*3 decks). You can get switches like that from RS and Farnell.
Best regards,
Mikkel C. Simonsen
not Lorlins!
I don't like them for any thing but a proto build I would never use them in something I wanted to last and rely on.
How many do u need?
I have some of these funky switches that i used in my summing box:
http://www.groupdiy.com/index.php?topic=820&postdays=0&postorder=asc&start=15
They are Alps and are 4 pole 6 posistion - but depending on where u attach the connector to the metal base thingy (where all the switch contacts are) you can make them into other min/max posistions - including 4pos :) I used em that way for left-center-right-mute...
Just to be clear - that long strip has a metal band in there that contracts/expands on each switch turn which moves the switch mechanism/contacts in that metal box on the pcb - so signal path is also kept very short. The pinout of the contacts is on a standard 2.54mm grid...
Give us a shout if interested :thumb:
Oh, yes these alps are fine... I need 8 - 16. I don´t know right now....
Are these PCB mounting ones? That would be cool.....
I am in Germany. So Where are you?... :grin:
@NYD I will take a look for these Alphas. Thanks, also for your design...
8-16 aint a prob and theyre PCB mounting yes - u can see in the pics pretty clearly no?
I'm in London, England...
ta
[quote author="daArry"]8-16 aint a prob and theyre PCB mounting yes - u can see in the pics pretty clearly no?
ta[/quote]
Ok, I could take a look in the left side where Londaaaan stands... :oops:
Cool, do you want to sell them? Howmany can you sell? Would be very cool....
> searching for a 4 pole/4position rotary switch.... and cheap
4*4="16"
The biggest common switches today are "12":
CONT ROT 1POL 12POS ______ 1*12=12
ROTARY 1P 2-12 POS ______ 1*12=12
ROTARY 2 POLE 6 POS ______ 2*6=12
ROTARY 3 POLE 4 POS ______ 3*4=12
ROTARY 4 POL, 3 POS ______ 4*3=12
RTRY 1POL 12POS SLDR______ 1*12=12
RTRY 2POL 6POS SLDR ______ 2*6=12
RTRY 3POL 4POS SLDR ______ 3*4=12
RTRY 4POL 3POS SLDR ______ 4*3=12
Therefore this is not going to be an easy find. Either expensive (and special-order) or a lucky surplus buy (and this is a good place to hear about such things).
[quote author="daArry"]:thumb:
how many do u need? :wink:[/quote]
Give me a prize and I tell you how many.... :grin:
[quote author="NewYorkDave"]Leslie, which schematic are you looking at? The design idea went through a few iterations...[/quote]
Oh, I don´t know. This little "LCRsum.pdf" with the ground routing of the unused resistors.
Sometimes you know, what you need, but the "routimg" makes you crazy, so it was a very good help, having this little pdf....
[quote author="daArry"]I have enuff !! :twisted: as prr said...
... or a lucky surplus buy (and this is a good place to hear about such things).
[/quote]
Ok, i will send you a pm for my lucky surplus buy.... :grin:
[quote author="NewYorkDave"]Try this...
http://electronicdave.myhosting.net/miscimages/16chpassivemxr.gif
http://electronicdave.myhosting.net/miscimages/16chpassivemxrpg2.gif[/quote]
Thanks. I ´ve seen this before, but I am using a Zero Ohm Input Summing Amp, so I only need to put the unused to ground. Thats all.
Thanks anyway....
