TomWaterman
So sorry chaps didn't mean to cut and run after starting this topic.
Can't believe its been almost 4weeks, ugh time flies...
Matt, sorry for not being more specific - this is for a mic pre/eq that I'm kind of designing from scratch based upon an old british design. I was going to do a powersupply for it with a separate +52VDC rail for phantom. +52VDC so each pre board with local slow regs would still provide a nice clean +48V after min. reg drop of 3V.
I was going to use a slow-reg based upon the LM317 datasheets, but subbing in the TL783C as you rightly suggested. Farnell seem to have them in stock again now BTW.
This PDF shows my original slow reg plus a simple passive RC one nabbed from JLM...
After some thought I've decided to scrap the PSU as I don't want to waste time on it when JLM make a nice one available for DIY'ers at a good price. So my design criteria has changed a bit. There will be a max of two channels in one box, a single JLM Powerstation providing individual +-V for each audio channel and a global +48V feed for both channels phantom (the 48V will also supply a separate TL783 for relays/leds and maybe two JLM DIs.
After reading yours, brads and mediatechs thoughts, the problem that any active slow regs on the preamp will drop a couple of volts means that I may end up with +45V. However I undertand that the DIN phantom spec is +-4V @ 48V so 44-52V is acceptable(?).
For sake of overall discussion here is Brad's TL783 linear ramp circuit that you all may like to see.
bcarso's 48V Reg PDF
I have enough board space left for a TO-220 reg or a darlington/JFET one...but am unsure of what to do.
Maybe the standard passive RC ramp shown as 'B' in the first PDF is adequate. I understand that the circuit decays and charges to 37/63% from 48v in a time of t=RC in sec, and approx 5RC for 1%, at least that what H+H says.
I also read somewhere about adding a 'bleeder' so that it will discharge quicker...any thoughts on that?
Really do appreciate all of your collective genius..
Thanks Tom
Thanks Tom
