imloggedin
Anyone know where I can get a 500 series front panel & L-bracket with PCB size specifications for my own DIY 500 series project (in the U.S.)? Thanks
if OP is willing to order from outside of the US, I've had frank at frontpanels.de mill brackets that required precision beyond what i could reliably do with a hand drill, and it didnt cost a whole lot extraYou would still need to mill or drill the bracket for your needs, so the results would be dependent on your machining skills.
If you have the complete mechanical details and dimensions of what you are looking for, I could easily create a mechanical design of the sheet-metal and then turn you on to a handful of "low-volume/prototype" sheet-metal fabricators here in the U.S.A. to have what you need to be made at a relatively low-cost.Anyone know where I can get a 500 series front panel & L-bracket with PCB size specifications for my own DIY 500 series project (in the U.S.)? Thanks
