jensenmann said:Did you use 25turn precision trimmers or single turn versions. With precision trimmers I could calibrate the servos down to the 10uV region.
benewell said:Hi There,
Long time lurker, first time poster, I purchased 2 kits last summer and they are absolutely Wonderful!
Unfortunately only the BOOST function for each band works on one EQ... I'm not able to cut at all. Has anyone experienced this, or have any hints I could try to isolate the issue?
I've:
- reseated the ribbon cable
- made sure TPS 1-TPS 2 read 0mv
- tested all switches and pots work mechanically, and are easy to switch/rotate
- tried different slots in 500 series rack
And I still have the same issue of not being able to cut with any band. My other EQ works flawlessly however. Any help or suggestions are greatly appreciated!
Brian
other notes: I also swapped R69's for 51k as per suggested earlier in the thread, getting a nice gentle +-, instead of the full 12dB. The only other issues I noticed are the mv's at each frequency band test point are slightly off (anywhere from 2-50ish similar to another user), but that doesn't seem to affect the functionality of the unit.
Studio Mollan said:Hey,
There must be an issue round about here in your EQ.
Check for cold solder joints or missing, faulty components. the ribbon cable is a candidate,. Try the one in the functioning unit, or check for continuity with a DMM. Truly great eq's!
Zander said:For those who used Pier Paolo's APP992, did you adjust or leave out some components.
Zander
benewell said:Thank you for the response!
Unfortunately I have been busy, but will try those suspects you suggested soon! I'm noticing that on my working EQ I added the optional C18a, as well as ccomp4 and compIC5. As I am a bit of a novice with circuit design and it was mentioned as optional/TBC, I wasn't sure if they were necessary... but am considering adding them to the non-functioning EQ.
Would it be beneficial to have those as well?
Studio Mollan said:Hi,
Yes you should fit them all. C18a isn't crucial, but recommended, but the Ccomp4 and compic5 should be fitted.
benewell said:Good to know!
I've fitted Ccomp4, compic5, and C18a, as well as found the issue (broken trace at the top of the PCB before R48). Both EQ's are back up and working flawlessly ;D
Thank you Studio Mollan!
baslotto said:Hey guys!
Not sure anyone is still hanging around here but I just finished 2 of these great units and all the voltages and measurements were right before I passed music through them.
Once I did that I realized that for one of the channels the BLUE gain knob won't do anything.
Can anybody help me figuring this out? It looks like all my soldering has been done correctly, I don't see any missing points.
I swapped the gain knobs modules to see if that affected the other module but it's not the knob module.
Any other measurements to help me identify where to start?
Thank you for any help.
Stefano
Studio Mollan said:try using the ribboncable from the working unit. It might be a bad cable.
baslotto said:OMG it was the ribbon!!!!!!!! These things sound insane!!
THANK YOU!! YOU NAILED IT!!!!!!!!
