Reddish 500 EQ
I'm happy to report that my unit, kindly assembled by Jordan (JMan), is also working and sounding beautifully. Very simple and easy to use for someone like me - a sufferer from an irrational fear of more surgical type eqs - but also quite powerful at the same time, which is exactly what I needed. Everything about it screams "quality" and, somehow, things like this feel much more special than commercially available gear.
I'd really like to thank JMan for his time, energy and generosity, but also Ian (ruffrecords), of course. Really looking forward to more projects like this in the future.
What a treat to see it racked up after only looking at it on my bench!
And yes, it just can't be said enough, Ian is awesome.
I think surgical EQ is overrated. It is fine if you want to cut some interfering frequencies bit not much else. The ancients got it right when they used broad boosting EQ. In some ways the Helios 69 EQ is the best of both worlds, broad peaking and sharp cutting.
My thoughts exactly. However, I had an Heritage Audio 1073 type eq before this, and even that was too much for me! Vastly prefer a more limited approach and the Redd is indeed perfect.
Got one set up and running, used vintage Australian made Harbuch transformers. Sounding great! One thing I noticed though is the front panels are fractionally wider than they should be, perhaps powder coating thickness not accounted for. Had to shuffle the order of cards in my 51x rack to get them next to some units that were fractionally narrower than necessary.
I had the same experience.
