Hey guys, anyone find the Dented pots? I have heard talk of a few guys wanting to use 10-12 position switches but I'm not sure those will fit with all the resistors and such. Maybe they will?
johnnyscotch said:OK,
I did the best I could on this.
Here's a Mouser cart with the parts that weren't included in Peter's kit. Save the pots:
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=546ee9f29d
Please anyone feel free to make suggestions/alter this if something won't work, it would be much appreciated.
I tried to size the caps to work, some of them may be too big, but it's all they had in stock.
My other question was about the IC. I put TL071 and 5534 on there (assuming they are the correct parts) and some 39pf caps for the option cap. But, what's the difference?? I'm assuming 5534 is better because it's more expensive? I'm probably going to take the TL071 off the list, but just for reference.
Jeff, will the switch caps you stock work for the switch? What about your PCB mounting hardware?
cheers all
Eric
peterc said:I would suggest finding the correct PCB mount part, it will make life much easier.
johnnyscotch said:peterc said:I would suggest finding the correct PCB mount part, it will make life much easier.
Any hints as to what that might be??
