Chris,fazeka said:For the IN-OUT switch, does anyone know what pushbutton switch Peter C supplied in the kit?
Has anyone tried the C&K F01 button as seen here on page 6? Will it fit the switch and will it fit in the hole in the front panel?
Chris
Don't have my kit in front of me, but from memory:pjdiy said:I'm having trouble deciphering the blue caps that Peter includes in his kit.
dmp said:Myles,
I think you have two of the secondary leads swapped on the output transformer, which would explain your reduced output.
I think the output should be (from top to bottom)
red
gray
green
blue
yellow
purple
The picture you posted looks like yellow and purple are swapped.
The primary is, from top to bottom (to have in-phase output)
red
brown
Yes, this is absolutely correct for an EA2503. The same way it was done on an original API EQ.johnnyscotch said:Can anyone throw any hints about wiring Ed's 2503 trafo??
This is what I plan on (from top to bottom on PCB):
Orange
Yellow
Green
Blue
Violet
Grey
Red
Brown
Is that correct?
