Quote from: Blackout on September 30, 2011, 03:33:03 pm
Boards and transformers have arrived! Thank you. Everything looks great! I just have a few questions about the FP48PSU. Should I use 1N4004 for ALL the diodes, or are there a few different ones? For the electrolytics I was thinking 50v for the 1000uf, 100v for the 100uf, and 63v for the 10uf. Finally, what should I use for the 2W in R2 & R4? Thanks and i'm sorry to even bother you with these questions in the first place. If any of the voltages for the lytics are off please let me know. Later.
- 1N4004 are fine for all diodes
- 50V for all electrolytic are fine
- for 2W use 47R
The 2W resistor(s) don't have any fuse function.
It just drops down the voltage a little bit.
No problem using a wire jumper instead.
surebraeden said:Are D-LA2A PCB's still available?
no, for 24V & 48V a single 22V AC is fine (there is a voltage doubler for the 48V)Hank Dussen said:Just to make sure: for the FP48PSU I need something like an 40 to 48v AC input right? (or dual 24v)
There's no voltage doubler for the 48v output, correct?
8)rjuly said:2 kits received with thanks! Looking forward to finding some time to assemble...
drumminkiger said:I would like to order a D LA-2A PCB set and the toroidal shipped to the US. How do I get this done?
