hey no problem, you are not here just to help me, im good, i need to think what i have done wrong in both cases, i cant think that i have, normally very good as this,
In the set up proc the first thing is to set the level, well i don't have any coming out so failed on the first thing,
it seems to me that the FET is being turned on all the time regardless of the side chain, but i need to look into it further, it has to be a wrong component value or wrong connection with the wiring, as its both units, its unlikely to be component failure.
the MORE/LESS pot is work like a kind of Gain at the moment, its increasing the small signal that i do have, and the hiss increases to, is that normal it should behave like that, as a gain? i guess so, whilst also feeding more signal to the sidechain, is that how it works?
Pete
