Another Ben, here. In the same boat, sort of. I've completely built up one of my two units. I can trace a tone into the opamp at 1.1V(started out with 3.9V at the input jack), then out of the upright opamp, i get 3.4V. My symptoms are very low signal once the comp is engaged, but once I tweaked R7 a bit, i started to get normal levels of audio, but the signal is distorted and coming in bursts, not unlike something thats been gated and sent through a distortion box. Which is cool, I ran some samples through and will use them, they sound F'd up. But obviously, not the end result I'm going for.
I'm thinking I need to crank more juice into this thing than my soundcard can push, either that or get a more sensitive meter to look at the AC. There are other test points on the PCB, little spots for your probes, where I can tell there's SOME signal, but its too low for me to see with my meter, except for the one between T1/A2, which reads something crazily high, like 34VAC. Anyone have a notion as to what "good" readings might be at these points? I'm going to remove my rotary switch and replace it with some resistors temporarily to troubleshoot, as I may have screwed that up; at the very least it seems the most likely problem at this point.
Also, I had C21(the tantalum) flipped around. Didn't blow up or make anything smoke, but I replaced it with a new one in the correct orientation. No noticeable change. Could anything have been harmed elsewhere in the circuit from this mis-orientation? I know enough to be dangerous to myself and my projects, but not enough to know the function of C21.
Anyhow, I'll post my findings as I fix things, but I'm sloooooowww. Thanks for all the great information!
bw
