6.3V DC can you explain to me
BOB42
Active member
FRANCE
Good morning all
a question about the 6.3V DC heaters
on the attached diagram I use a configuration from this forum.
I can not decipher and therefore calculate the output voltage.
_using HT center tap as ground
_and creating a virtual ground via the two 470 Ohm resistors
can you explain to me how this circuit works?
thank you
BOB
  • Schematic_6.3vdc.pdf
Good morning all
thank you
BOB
The 470r resistors are there to more or less balance the voltage both sides of ground (0V). Actually, it's the AC voltage that is balanced, so the DC voltage is not equally balanced.
But the important thing is the AC ripple is equally balanced, so it minimizes hum induction.
In order to get the best, the two resistors should be connected at the outputs, one between + and gnd, the other between - and gnd.
For the rest, the circuit is pretty much straightforward.
Hello and thank you
here is a new diagram
I hope I understood
if this diagram is wrong can you make me a sketch to give me the right direction.
thank you
BOB
  • 6.3DC-2.pdf
Thank you again for your help
attached new diagram
I hope I understood!
BOB
  • 6.3V DC3.pdf
Here we go...
Note that I offer no guarantee as to how it would perform, since it sepends on the actual transformer and what tubes there are to power.
Thanks a lot
ground comes from HT center tape (300-0-300v)
transformer: Hammond 372 DX
the tubes: 1 EF86 tube and 2 E88CC tubes.
so 3 solutions for heating:
_ 6.3V AC
_ 0 /+6.3V
_ +3.15V /0 /-3.15V
what would be the best solution to limit the background noise?
BOB
That Hammond is overkill for a single Redd47 channel, it doesn't need such high currents, it's also physically large and expensive.
If mounted inside the same chassis as the preamp circuitry there will be quite some noise radiating from the transformer.
I would be more worried about this than AC or DC heaters and I prefer using a toroidal transformer to reduce noise.
Even with DC heaters 1A should be enough for the 6.3V winding and the HT winding probably needs no more than 40mA
I have used this transformer for similar preamp projects and it works well, you also get a spare 12V winding which could be used to power relays, led or other stuff
https://www.tube-town.net/ttstore/toroidal-47va.html
Simulation shows 1.8 Arms.
With the Hammond xfmr, the two 1 ohm resistors should be slightly increased (about 1.5r).
I agree that incorrect placement and orientation of the xfmr could result in killing all precautions taken with heater voltage filtering.
Heater current is 200mA for the EF86 and 300mA for the E88CC
The op mentions above two E88CC tubes but in fact the REDD47 has only one, with the two triodes wired in parallel
I thought that if the heaters take 500mA AC, then with DC you would expect around 1A. And the 1.5A transformer I suggested should definitely be on the safe side.
Actually, in post #14 I had read it used two E88CC, but in fact it's only one. E88CC heater is rated at 365mA.
So the resistors should total 6ohms. 2.7 a,nd 3.3 should be OK.
Simulated RMS current is 1.2A. Of course need to be checked by experimentation.
thank you both for your involvement
the potentiometer is a good idea
my project is the passive REDD47 + REDD EQ
the preamp has 3 lamps
1x EF 86 (6.3v 200mA)
2x E88CC (6.3V 300mA each)
because I added a buffer to resume level after passive EQ
the transformer is oversized because if the result suits me
I would do 2 channels.
on the 372 DX there is a 5V winding which allows me to use a GZ34 rectifier
on the HV winding there is a 50 VAC output
that I would like to use for phantom 48V
(it is true that one or 2 toroidal transformers would be less noisy)
initially a channel
tell me if my calculation of theoretical resistance is good
200mA+300mA+300mA=800mA
6.3Vac x 1.414= 8.9V -2V (diodes) = 6.9V-6.3V =0.6V/0.8A=0.75 R
the value seems wrong to me
I don't see or is it wrong?
BOB
