BluegrassDan said:I see. Does it matter that I'm using a shorting stepped gain switch?
Would 2.2 meg be appropriate?
emrr said:The 1M is in theory good practice....in practice it has not been included in 99.99% of professional tube amplifiers made since the dawn of time.
Matador said:am I reading that schematic incorrectly, but it looks like the second grid (V1 1/2) has no DC bias?
emrr said:I believe your build appears to be headed for short run production status, based on the panel design threads at realgearonline?
emrr said:It does, look gain. Strangely drawn. Shield includes bottom of pot and ground.
emrr said:Transformers are going to be most of the action. You already have a Jensen input. You can go to their most expensive most linear input transformer with step-up, and get a little more, but people will complain about low gain.
bluebird said:Exactly...I've come to find that the input transformer and it interfacing to the first stage is 90% of a pre amp sound. Tube or solid state. Unless something in the design is wrong. The Jensen doesn't have a dual primary, but if you use an input transformer with a dual primary you can give people a choice of series parallel with a switch, usually labeled 150/600 ohm. The series position (600ohm) will definitely give people a more "open" sound but less gain of course.
For instance if you used a Lundahl LL1578 You could employ the series parallel switch.
http://www.lundahl.se/wp-content/uploads/datasheets/1578_8xl.pdf
Seems you already have your panels made so I guess its a moot point.
Regarding the output transformer, I've always had a love hate relationship with Edcor's. Love them because they are cheap and get the job done, but hate them for any serious fidelity work. I believe they use the minimal amount of wire/wraps for the minimal amount of inductance to get by. All on a steel core. Since there is no DC in the output and its a step down I really don't know to what extent its affecting the over all sound. Like I said before you can just try it with no output transformer at all and if you like the way that sounds but need it to be balanced, get a Lundahl...
Its all project specific but my general transformer rules are:
Edcor to mess around
Jensen for a middle of the road nice sound
Lundahl for a transparent "nothing there" sound
Vintage UTC or Triad for the best sound ;D ;D ;D
Bill Wilson said:In order to make the 6027 stages as quiet as possible, eliminate C1 & C3 cathode bypass capacitors. They are an old trick to squeeze more gain for the stage. When you increase gain you also raise the noise level. It is for this reason I recommend eliminating them.
Bill Wilson
