Dmichel123
Yes. Reading 3V + 3V = 6V.
scott2000 said:Maybe there is some kind of connection goofed somewhere....
You mentioned that you elevated "all" the heaters at some point? How did you do this? Were there any connections that needed to be modified in order to make this happen??
Or maybe as CJ pointed out, the method used to rewind may not have been the best for this setup.....
Dmichel123 said:I disconnected the wire that went from CT to ground and fed 100VDC into that CT.
scott2000 said:Where was that? At E3??
Dmichel123 said:That CT is now connected back to ground, as it was originally.
It's a wire that goes to E16-4, up to the control chassis to E10-2, up to the amplifier chassis to E3-2, and then to ground in that chassis.scott2000 said:Where is this ground located?
