a.c. heaters
merlin said:
ruffrecords said:
1:10 is very common in tube designs. It is the only way to achieve a reasonable noise figure.
OK, that makes sense. I am so used to thinking of regulated DC heaters -which leave you with the irreducible noise of the first valve- that it wouldn't occur to me to use more than 6dB of step-up. Not so for traditional AC-heater designs where you have hum to think about too.
Anyway, using a high step-up input xfmr also optimizes the contribution of the intrinsic valve noise. I don't see any believable justification for using a 1:2 or 1:4 xfmr vs. a 1:10. The only limit there is the HF response which suffers from the higher leakage inductance. The practical limit seems to be about 1:12, although there have been examples of 1:14.
The irreducible noise of vacuum tubes, even with dc heaters, is high enough that a respectable EIN is not achievable without an input transformer ratio in the region of 1:10.
What surprised me about the tests with ac heaters was that figures as good as with dc heaters were obtained.
As you know, the Lindos MS10 I use for noise measurements meets IEC268 ,which can give noise measurements as much as 8dB higher than more common rms measurements. The Lindos measurement of -121dBu EIN with ac heaters could arguably be -129dBu rms which would be an exceptional result.
ian
> That's 20dB of step-up even before you start!
Mike hiss is say 0.2uV.
Transistors "can" get down in this part-uV zone.
Tube hiss is closer to 1uV. Unless we do something heroic, like a TV-tuner tube running 13mA.
1:7 to 1:15 are usual ratios in tube-work. The higher ratios are either PA-quality (limited/ringy top end) or come from very clever designers (Beyer for one).
OTOH there are studios with all high-level condenser mikes and any darn ratio is ample.
What has always surprised me, as you may have noticed, is people feeling the need to use DC heaters.    I keep running all these antique tube amps with AC heaters, and never hearing any hum, and no one believes me.
When I first started designing tube mic pres over ten years ago I began using a triode strapped 6AU6 (some old BBC mixers used this configuration). I had dreadful problems with hum and finally had to resort to powering the heaters of my test rig with four AA batteries. Since then I have always used dc heaters. It is only now with ten years experience under my belt and some designs I know work well that I have fortuitously tried ac heaters again and as you know been pleasantly surprised. Consider me a convert.
Last night I was listening to a CD of tracks from the early days of Sun studios. Several tracks had breaks in them. Putting my ear right next to the speaker I could hear some hiss in these breaks but not a trace of hum.
I do  ;D
