I have this SM PRO HP6 headphone amp. It works ok but it's a bit noisy. I'd like some advice on repairing it.
There appears to be some burnt out resistors on some channels. The board is marked 10R in theses locations which I assume should mean a 10ohm resistor goes there, but they appear to be 47ohm resistors.
I also see that it has NJM4558 op amps, when the literature says it's suppose to have NJM4580 op amps.
Since the quality control of SM pro products were always questionable anyways, I suppose it could be that the builder put in the wrong components? or because they decided to put in NJM4558 op amps they changed these resistor values for some reason?
So on to my questions:
1. Should i:
A. Replace the resistor with the same value that was installed? (47ohm)
B. Replace the resistor with the value marked on the board? (10ohm)
2. Should put in a resistor with a higher wattage rating? (specs say max 1W @32ohm per ch. )
3. Should i swap out the opamps for different ones (NJM4580, NJM4562, NE5532)
Any help is greatly appreciated.
It should be noted that with the resistor problem aside my plan was to change the all the caps to higher quality ones.
Also I've tried to get the schematic but have been unsuccessful. if anyone has ideas on that please say so.
Pictures:
The insides (I unhooked some of the cables that were in the way)
The headphone output section with burnt resistors
Resistors from another channel (not burnt)
Power transformer. (17v x2/0.45a)
One of the line input sections for anyone interested
1. Should i:
Pictures:
