Thanks, I'll take à lookTillM said:Volker has some nice PCBs for your project.
Look at the white market @silentarts
NannerPuddin said:Finally got my first four working. It was a ton of work getting them squeezed into a one unit enclosure.
fauxjazz said:Both pres seem to work properly with dynamic mics (and seem very quiet), however enagaging the 48v results in a lot of noise on both channels.
The noise is not hum but rather hiss
madriaanse said:I’m impressed you were able to squeeze four into a 1U rack! Nice work! Any problems with crosstalk?
NannerPuddin said:So that video has me good and scared, so I wonder if i might be missing something in my test. The output during the test on the hot channel close to 0dbfs. I had the gain all the way up on the other channels and all that came through was some faint noise floor sound. Pretty quiet, though.
rp3703 said:Hi All, I know this thread is a decade old now but since it has replies from 2020, it thought I'd give it a try.
rp3703 said:Last night I used an oscilloscope and noticed that the level on one side of the balanced signal is lower than the level on the other side. Is this normal? Am I looking at it wrong?
The signal at a balanced XLR exists only between pins 2 and 3 and on a balanced TRS only between tip and ring. Pin3 and the sleeve are the connection for the screen. It is not a signal connection. There is no definition of a signal between tip and screen or between ring and screen. This is especially true for Neve transformer balanced floating outputs.rp3703 said:I actually used TRS for outputs but the Tip has a stronger signal than the Ring. I guess I need to take another look at my output wiring again.
ruffrecords said:The signal at a balanced XLR exists only between pins 2 and 3 and on a balanced TRS only between tip and ring.
Yes, I am afraid you are wrong. A floating transformer is not referenced to 0V (except perhaps through stray) winding capacitances, The signal exists only across the secondary winding of the transformer which are connected to pins 1 and 2. You do not need pin3 to send the signal to another piece of equipment.Whoops said:Well but those are 2 signals, one in Pin2 and another in Pin3, and those can be measured individually with a 0v reference. Am I wrong?
Thanks Ian
ruffrecords said:Yes, I am afraid you are wrong. A floating transformer is not referenced to 0V (except perhaps through stray) winding capacitances, The signal exists only across the secondary winding of the transformer which are connected to pins 1 and 2. You do not need pin3 to send the signal to another piece of equipment.
People often get confused about this because electronically balanced signals ARE each referenced to 0V and often they are the same value. But they do not have to be the same value to be balanced ( e.g. impedance balanced) nor do they have to be referenced to 0V.
It is exactly the same as the mains supply coming into you house from the local utility transformer - the voltage and the power exists only between the live and neutral. In some countries (like the UK) the neutral is connected to earth so if you measure between earth and neutral you get zero volts and between live an earth you get mains volts. In a floating system neither live nor neutral is connected to earth. You still get mains volts/power between live and neutral but it is anyone's guess what you get between live and ground because they are no connected.Whoops said:Thank you so much for explaining Ian, I really have to study better about that.
i really can't get me head around of what that is in reality. I can understand electronic balanced signals, there AC on PIN2, the same AC on PIN3 but with reverse polarity, and on the on the next input one of them has the polarity reverse and summed with the other.
With Floating I really don't understand the concept...
