rp3703 said:So did either of you answer my question? Is it normal operation to see signals on my scope at different levels. It was the same for both channels of my two channel EZ1290.
The answer is with a floating transformer output such as the Neve 1073 has, there is NO SIGNAL between hot and ground or between cold and ground. Anything you measure this way is due to stray capacitances. The signal exists ONLY between pins 2 and 3 on an XLR or between tip and ring if using TRS.rp3703 said:So did either of you answer my question? Is it normal operation to see signals on my scope at different levels. It was the same for both channels of my two channel EZ1290.
No, because the output is floating.rp3703 said:Ok, so when I bias the output, I need to connect my probe and found to pin 2 & 3 or tip and ring in my case? Does it matter which one goes where?
ruffrecords said:You don not appear to have any of the XLR pins 1 connected to the chassis. You also do not appear to have B- connected to chassis at the power in connector.
boomfred said:Thing is I’m waiting for a front panel, so I just put some plastic board in front of the unit for the moment.
And I do have a ground issue with the Grayhill (touching it make it buzz, and connecting a wire from the back of it to the ground lake the buzz go).
boomfred said:I only use plastic standoffs.
And yes I did clip some wires from the switches to the case.
Thanks.
Another question.
I only connect Pin 1 of the inputs to the ground.
Should I do that too on the output XLRs ?
(cause I think I shouldn’t...).
boomfred said:I am building a dual ez1290, I thought I did well but obviously, I didn’t.
Here I am with the oscillation high pitched noise. I swapped 2n3055 and I am using shielded cables for audio.
The problem is the same on both of preamp, so I assume I did something wrong but I can’t see where/when/what.
boomfred said:What picture do you want ?
boomfred said:Here’s a picture of the PSU.
You can see the green and yellow wire connected to the ground of the PSU. Then I have a 4 wire cable running to the rack case (case, 0v, 24v, 48v).
I will re-check the ground scheme tomorrow, that’s a lead.
boomfred said:Although, I don’t get something.
If I connect XLR’s pin1 to the case of the rack, I do connect too the case to 0v of the PSU, which is not supposed to happen with the JLM PSU.
Am I wrong ?
