Dazazone
ok it seems one of my 3055 legs was touching the heatsink! The heatsink measured 23.5V, nasty. Fixed and now the 50Hz hum is gone! woo! :-*
scottlangendyk said:Awesome project, are PCB's still available?
EDIT: E-Mailed Martin and was informed that they are available
Had a few questions though for fellow builders.
With regards to the power supply, is there any reason to use the transformer listed in the BOM, or will any transformer work as long as it's outputting 24 volts?
desol said:It depends on how many channels you are building...how many amps you need. Two channels can use a smaller transformer than 8 channels. It also depends on which power supply your using. If your using the JLM stuff, you'll need 24vac.
statzern said:No, desol - the one you want is a 22-0-22 transformer.
If you get the 24 VAC one, you will not be able to get your +48 up to 48. And probably will have issues with your +24 too. I had this issue, and I am 100% sure that you NEED to have more than 24 vac.
