8 Channel, 3U NEVE 1073 completed
Hi
Here is an email from Martin :
My understanding is that Neve used BC107/BC109/BC184 interchangeably. BC107 and BC109 have been replaced with BC547 and BC549C respectively. Using the EZ1290 layout from here:
http://s3.amazonaws.com/EZ1290/transistor_voltages.pdf
You can use:
BC549C for TR1, TR4
BC547 for TR2, TR5, TR6
2N3055 for TR3
Le Roux said:
Closer inspection last night reveals that my original fairchild's have the "f" then BB13 in small hard to read writing next to it, and the ones I ordered have the "f" with BA41 in small next to it.
I tested the hfe, and they averaged around 450, where as all 8 fairchilds I have tested around 300-350.
I do think they're good to go!
Finally got mine too. It seems that they have different labelling on them, "BA12", "BA17", "BA35" and "BA41". I haven't tested them yet, but do anyone know what these different markings mean?
Does also anybody know why there hasn't been the 2200u 25V capacitor on the BOM?
Or has there been a change in value?
Such as C4, C6 & C7 (Capacitor Electrolytic 82uF 25V) which are maybe for this purpose and therefore deviate from the board's indicated 100?
*Edit* I simply chose 100uf 25v capacitors for the not corresponding 82uf and took the missing 2200u capacitors also into my cart. Wondering why it is not listed under the official metal BOM.
Anyways, what I'd still like to know is what it means to draw EH10023. I suppose this is a section of the board but nothing more? Does it have to be tapped (possibly by placing the 180uf capacitor there) in a way of modding it to deliver more gain? Didn't find a hint throughout all the thread's pages.
Hi All,
Finally got around to building this pre. I found a stock of BC184C at Future Electronics, OEMS Trade is great for sourcing hard to find parts. I have a problem with this build though. I have not gotten my Carhill Trafo's yet but had some old Neve's laying around.
Mic Input is Belclere TF10016
Output is Big Orange VT24499
Pre is passing signal and amplifying but I have a drastic difference (about 25dB) from 100Hz to 10kHz, with 1kHz in the middle. Frequency response is way off. I wouldn't think that the trafo's would cause this, but I could be mistaking. Let me know if anyone has any thoughts. Solder On!!
I chose these for that purpose:
http://uk.mouser.com/ProductDetail/Nichicon/UKA1E222MHD/?qs=ZkXqA7GzKJJMuw8S3Hf38Q%3d%3d
http://uk.mouser.com/ProductDetail/Nichicon/UFW1E101MED/?qs=kArNe9LFxXmnkbKvib80gQ%3d%3d
Also noticed that you were all building external power supplies. What if I isolated the power-section with metal plates and anyhow, don't toroid transformer cause the least trouble in audio racks with the unit's transformers?
Depends on how many channels your going to build. Toroids are noisy...even to units
above and below in the rack. Placement and good grounding practices is everything.
I used some mu foil to add a litte extra shielding where needed.
Gonna put two neves in the same box with two ssl 9k so it won't be that bad whereby there is another build with four apis in one box.
How for example would be the best placement of a toroid transformer? Horizontal or vertical?
I don't know, i think it's noisy either way. You can try looking on a scope or just listening and turning it to see what's best.
One of these probably wouldn't hurt: http://www.don-audio.com/trafo-shield
Make sure the inputs and transformers are shielded/placed properly and you won't have any problems.
Seriously? I mean aren't builds such as the 1176 also prone to such noise floors and still several people just put the transformers in the same enclosure?
What if I shielded every ******* thing that resembles a magnet as you said including the unit's transformers? :D
And about the grounding I shouldn't have to be worried since a put a lot of effort in grounding the **** out of my builds.
I'm just trying to be reasonable considering what people do with their other builds, including people that have also posted on this thread.
Well, i mean you wanna use de-facto carnhill inputs as they will be shielded properly. The rest is just common sense and experimentation.
I'm putting together a dual ez1290 in a 1u case. What length stand off did you guys(who used a 1u case) use in order to have the gain switch remain in the center. I assumed I should simply divide the 1.25" (2u case) in half to a .625" standoff. Advice?
That's the tough thing...exact measurements, to avoid unneeded stress on parts. Mine were installed vertically....so there were no feet. But for the things that i did need exact measurements for, i used a digital caliper...then checked...double checked...triple checked, quad, quint, etc....in reference to my frontpanel layout.
Time consuming, but it's worth it. Get as close as you can...then shim with plastic washers, etc...if needed.
Hey team,
is the only reason for not using BC184LCs the pinout? I was wondering cos, i have found a stash of them with HFE all around 650 and to rearrange the ECB to EBC is quite easy.
thanks for any help
Michael
I'm not sure I understand correctly, but if you center the gain switch on the front panel the pcb won't be in the center, since the pcb mounts to the bottom of the switch. I think I used either 1/4" or 1/2" standoffs when I built mine.
I wasn't refer to the PCB as the center, I assumed 1.25 length used in the 2u to be relative and therefore the 1u case would require half the length at .625... Hmmm maybe
Best thing to do is created or draw a mock up on paper. Do you have the case already? You could use a caliper and take case measurements, draw them exactly on paper(drawing it like a sideview)....assume a standoff size...say 8mm, draw them in, then draw the pcb/switch and find out where it ends up on the frontpanel. That's where your switch hole, etc would go.
Adjust from there...
