the JLM add on (which i have on all 6 of my pres) doesn't have an impedance selection. :-\ :'(
desol said:Feed the powerstation what it wants...24vac to 30vac.
Edit: actually, joe has a new spec on his powersupply. Apparently 15-30vac now...so you should be ok as long as you have version 3...i guess.
http://www.jlmaudio.com/shop/index.php?_a=viewProd&productId=12
atticmike said:desol said:Feed the powerstation what it wants...24vac to 30vac.
nah, rather talking about 24v the pre needs but still being able to power it properly with just 22v secondary since the capacitors load up and with its saturation level out the gaps?
desol said:atticmike said:desol said:Feed the powerstation what it wants...24vac to 30vac.
Well, you have to feed the powerstation v2(24-30vac) and v3(15-30vac) then it's rectified, filtered, etc to your adjustable DC voltage...so whatever AC input voltage it wants, is what you need to give it. You have 22vac...so if you have a version 2 powerstation, that's not enough. Or, consult Joe about it...
Siegfried Meier said:Hey guys,
I have a dual channel 1290 here that has one channel humming and has a thin output, no low end. I've built up a number of these, but have never encountered something like this. I've scoured the thing for hours on end, checked solder joints etc. Any clue where to look for what might be wrong?
Sig
